Jan 11 14 7:41 AM
Mod the aux jack to work with an after market radio. You'll need a stereo cable "in" jack on your radio.
Pull the switch panel, pop the aux jack out through the front and remove the wire harness. Pop the 2 clips on the side, slide the front off, then push the entire jack assembly out through the front. For instructions on how to remove the switch plate assemble, please see http://rollmeover.forumer.com/how-to-add-another-12v-power-outlet-t1307571.html
Buy a stereo cable extension, female one end, male the other.
Lock the female cable in place using another stereo cable, then apply epoxy.
When dry reassemble
Done, I can now enjoy Pandora in my FJ
